For full features; Go to 92 Toyota Corolla DX automatic transmission slipping/no shift
I have a 92 Toyota Corolla DX, 1.6Ltr transaxle with 3 speed automatic
transmission.
There is an intermittent problem with the transmission that does not happen
all the time. It usually happens at about 45MPH going up a slight hill or a
steeper hill it shifts from 3rd to 2nd as it should, but instead of going
into 2nd the transmission slips and transmits no power as if it was in
neutral. When this happens the only thing I can do is slow down an manually
shift to 1st, then the only gear that works is 1st, if I manually shift to
2nd or drive it just slips like it's in neutral. If I stop the car and put
it in park then the transmission usually works properly again.
The transmission fluid looked good and was at the correct level.
I have had the car in the shop for transmission flush, but the problem
remains.
Can anyone tell me what the problem is??
thanks
mycarr
I posted this 10 days ago, no reply.
mycarr
I'm not sure that anyone here is much of a transmission expert. From your
description I'd say its time for a rebuild. You could try some of the
transmission additives that stop slipping, but it would be a very temp fix
at best. I suspect that the second gear band is bad. Under normal load it
manages to perform, but under heavier load such as a hill it begins to
slip. Once it begins to slip it continues to until you stop. Which gives it
time to cool off. This is possibly why it works.
This is the best answer I got. Other wise find a good transmission shop and
explain the problem. But expect a rebuild in your future.
corbett_auto
Fried clutch pack?
Wally
If second gear was bad, of fried clutch pack, or over heated, the
transmission fluid would be burnt.
The transmission fluid is not burnt, it looks and smells fine.
mycarr
