For full features; Go to rad flushing 2000 dodge caravan
What procedure is best to flush the rad and block on a 2000 dodge caravan 3
liter?
herkey2
i would drain your rad fluid into a container through the bottom plug and
then just run water out of a garden hose through it for a few minutes, i'm
sure there are some additives or cleaners out there you can use if you have
mineral deposits. Just remember its got glycol in it so use rubber gloves
and try not to spill any.
cowman85
