New Problem with 94 Prelude Overheating. No one'sbeen able to solve.
I have a 94 prelude that i had the engine replaced in back in November.
Everything was running fine, but the car would go past the middle point for
temp when the car would sit for a while, but then it would go back to the
middle point on its own.
Well, last saturday i was on a gravel rd and i peeled out and gravel kicked
up and about 5-10 minutes later, i notice the temp gauge was all the way
hot. I have changed the thermostat, blead the line, and refilled the
coolant and the car gets hot is only about 1 minute. It literally goes from
off and cool to all the way hot in about 60-90 seconds. Also, although the
temp gauge is all the way hot, the radiator cap, plastic resovoir, no
hoses, or the engine is hot. I take the radiator cap off and the coolant is
not hot at all.
what is my issue. Please help?
Sounds like you have a hose that is clogged or a bad water pump. Obviously the water is not circulating from the radiator to the engine. Also check the fan belt. And finally are you sure the thermostat is not in upside down?
i put the therm in just how the other came out, so i guess its not bad. I guess it could be the water pump but how can i check to confirm.
If you had cooling problems before you replaced it it could have been in
wrong before too. Not sure a real good way to tell you how to check if the
water pump is working..... There are a few ways, but you need to be real
careful. BUT, if the thermostat is in upside down the water will not
circulate well anyway.
To see if the pump is pumping follow these steps:
Remove the radiator cap
crank engine
after the engine warms up and the thermostat opens
you should be able to see the water circulating by looking in the
radiator.
Is the belt turning the pump?
