car forums
97 Lumina Stalling
For full features; Go to 97 Lumina Stalling
My question is concerning a 1997 Lumina with a V6/3.1L engine. The problem started out with a water pump leak and the engine running warm. The engine stalled, but was not overheated. After setting for a while I was able to drive it home and replaced the water pump. The stalling continues to be an issue.
There is no cooling fluid loss and the oil is clean. The car will run in idle indefinitely and runs smooth. The electric fans are cycling on and off as expected. But, when you drive it, after roughly 5 miles it will just stall. Up to that point the car feels and acts as normal. The stall can happen at regular driving speed, while accelerating or decelerating. You can restart the car (it runs rough and backfires) and continue say another quarter mile. Then it will stall and not start. After a cool down period you can start the entire process over.
I replaced the ECM thinking that it may have been overheated and damaged. This was not the issue.
Any help? posted by  shadetree
Ok, I borrowed a code reader. I am only getting one error. It is “Crankshaft Position Sensor A CKT Range/Performance”.
All ignorance here. What is this telling me? Does the sensor need replacing or is this indicating another issue. If it is the sensor that needs replacing, where would I find it?
Could this actually be causing the original issue that I described? Any help or input would be appreciated posted by  shadetree
I'm assuming the dealer would carry the product you need...I did a simple Google Search for the error code and got lots of hits. Some with possible problems causing this error and some simply saying replace the sensor.
Have you done this already?
. posted by  BavarianWheels
it's saying that the reading the computer is getting from the crank pos sensor is not what it expects. it could be a bad sensor or a wire rubbed thru or grounding. most likely a bad sensor, though. good luck posted by  dodger65
The crank position sensor is easy to replace and can be picked up at most auto parts stores. The sensor is a small cylinder on top of the crank case at the front of the motor held on by one small screw and a plug on the top. Takes at tops 10 minutes . posted by  catinthehat
