For full features; Go to 1998 ZX2 Ford Escort.. AC switch question.
My 98 ZX2 all of a sudden decided it no longer wanted to shoot the AC or
heat out of the dash vents? All the other vents work the windshield and
floor are now the only place the heat or AC comes out of? :banghead:
Anybody have any suggestions?
Enigma4444
enigma4444
The default for all vehciles, is for the air flow to come out of the
defrost ducts ( with some leakage to the floor) if there is a malfunction.
Is that what it is doing? do you have cold air coming out of the defrost
duct? The blend doors and mode doors are controlled by electrical or
vacuum motors when you press the buttons. Does the heat/cold blend door
change the temp when you move it?
Do you hear any of the other mode doors move whne you press the other
switches? I would suspect it's the heater/a/c control head (with all the
buttons). good luck.
engineer
