car forums
High idle
For full features; Go to High idle
Got a 1994 tempo with the 2.3. soon as u start it up the idle jumps up really high then after like a minute it drops down the car dose not stall out. I am tempted to replace the idle air control valve cause i think thats what it is but i heard it could also be a ect. i know this is a problem with these cars just had to stick 250 to get the damn harmonic balancer replaced cause it was seperating and making a howling noise but i am rambling on but u got any suggestions it would be nice to hear them. posted by  sillybob22
I think you've got it figured out, Bob. Go ahead and replace the IAC. If that doesn't fix your problem, throw a dart at the board to see what part you'll replace next. Keep going until you repair the car by process of elimination. Or...
You could start out by checking for DTC's and follow the path. You could perform actual diagnostics/troubleshooting and replace only the part(s) that need to be replaced, assuming anything even needs to be replaced. You could save money and have the pride of doing the job right the first time.
But that wouldn't be any fun, would it? posted by  vwhobo
how about i replaced the iac ohh and wait i fixed the problem there thanks for the worthless post i got an idea how about i take a dart and throw at ur head. posted by  sillybob22
