car forums
Oil Light Flickering
For full features; Go to Oil Light Flickering
Hi Everybody,
I have a 2002 Mitsubishi Eclipse GS and sometimes when I'm idling my oil light flickers on and just with a tap at the gas it goes away? Why is this? Also I have a question about the intake on this type of car can u manufacture your own home-made cold-air intake ... I know you can on the 99's. Thanks for any help its very appretiated.
http://i196.photobucket.com/albums/aa93/icecrack1/car1.jpg posted by  Eclipse02
Check the oil level first off (with the car at operating temp and off). The oil lights generally comes on when oil pressure is low. If its flickering on, it could mean the pressure is just dropping low enough for a split second. posted by  Mathew
or a bad sending unit - verify engine has adequate oil pressure with a gage then if is good, replace sending unit posted by  tbaxleyjr
