car forums
Are my coil packs bad?
For full features; Go to Are my coil packs bad?
I forgot to replace oil cap, plug holes filled up. Cleaned holes, the car sputtered and idled rough. Replaced plugs and wires, car misses during acceleration, and idles roughly, dropping to nothing, even stalled itself 3 times. I'm thinking maybe a faulty coil? Here are some pics.
Sorry, don't know how to put a pic in this thing!
Look at the one on the left. It is corroded, and mishapen.
Do you think that that is the problem? posted by  johnnyb15613
Any chance you allowed oil into the cylinders when you removed the old plugs? That in itself is no biggy, but there may have been enough to burn and gum the shiney new plugs. Take a couple out and see if they need a bit of a clean with a bronze brush.
Otherwise make sure the leads are properly snugged into there correct sockets/standoffs on the coil, dizzy, coil packs, whatever (sometimes compressed air trapped under the plug boot can push the plug out). Also check the caps on the sparkplugs are tight. If it's a dizzy, pull the cap and check the electrodes are scraped clean of silver oxide deposits.
Did you buy the correct gap plugs? posted by  Wally
