car forums
Emergency Brake Doesn't Work
For full features; Go to Emergency Brake Doesn't Work
2002 Nissan Sentra, automatic.
Not that it's a big deal, but unless I pull the emergency brake all the way up, the car won't stop. Even when it's pulled up all the way, it barely holds. Is there a way I can fix this for cheap at home. It's not really worth going to a mechanic over and I really only use it in empty lots ;).
Anybody have suggestions? posted by  chris_knows
need shoes? posted by  bullrage2003
What does your manual say about adjustment? posted by  vwhobo
It says:
Parking Brake
6 to 7 Clicks - under pulling force of 44lb (196N)
From the released position, pull the parking brake lever up slowly and firmly. If the number of clicks is out of the range listed above, see an authorized Nissan dealer.
I pull it up probably 10-12 clicks and it barely holds. posted by  chris_knows
sounds like that came from your owners manual, not the repair manual. posted by  thefonz
Sounds like you're right.
I don't want to waste money on a repair manual though, because it's my dad's car so I'm only driving it for another month or so. posted by  chris_knows
So you wouldn't spend that small of an amount for your own father?? Shame on you. :clap: posted by  thefonz
$30 or your fathers safety, and you take the $30, what is this world comming to...:laughing:
Edit: just for you chris400 POSTS!!! posted by  dvdrose18
It's an automatic, when do you use the hand brake other than to impress people? lol Seriously though, could that be a safety issue?
LOL 400 posts. 100 more and you can change your name thing. posted by  chris_knows
if something bad happens to your regular brakes it could be a safety issue, there is a reason it is called an emergency brake. posted by  dvdrose18
Yeah but in the owner's manual it's called a "parking brake". Not once in the entire book is it referred to as an "emergency brake". Semantics aside, I see what you mean. I'll tell my dad to fix it though--I can barely save money without fixing his brakes lol. posted by  chris_knows
Jeezuz how hard is it to pull the console off and adjust the two cable nuts going to the hand brake lever? It's probably mainly cable stretch, but also check your rear brake/handbrake pads. posted by  Wally
