For full features; Go to mustang 2.3 running problems
alright lets start with car runs runs great for awhile then runs like crap
acts like it going to stall so pulled over put it in park and ran a little
better put it in gear and stumbled again acts like its running on 2
cylinders..... but, last week i replaced the igniton control mod and idle
air control or bypass valve and got rid of thos codes ran GREAT intell to
day when problem occured i scanned it with my obd 1 connector for ford and
got these codes
332- insufficient egr flow detected
411-cannot control rpm during koer low rpm
538-insufficient rpm change during koer dynamic response test invalid
cylinder balance test due to throttle movement during test
536-brake on-off switch or boo circuit not activated during koer
521-power steering pressure switch circuit fault
any ideas i need HELP where to start lol o and if it helps my heater used
work to but since i replaced the ignition mod now it does nothing!
kcheifs28
Would be noce to know year and other pertinent information - based on
trouble codes, I will assume you have something built between 1989 and
1995
332- insufficient egr flow detected - your egr system measures pressure
differential across the valve to give indication if it is working or not.
Wither a bad EGR valve, a bad solenoid which operates the valve actuator. a
bad diaphram in the vacuum actuator for the valve, or clogged ports at
either the exhaust inlet or egr valve outlet at the intake manifold.
Fortunately, your Haynes or Chiltons will give you the exact diagnostic
procedures for this specific car.
Both 411 and 538 indicate there is an issue with the idle control circuit
or an issue with the TPS or the throttle body its self.
536-brake on-off switch or boo circuit not activated during koer - the test
procedures for KOER test require pressing the brake pedal during the test -
this was not done and should not indicate a problem
521-power steering pressure switch circuit fault - the power steering
system has a pressure switch to tell the ECM you are steering the car and
to adjust idle to compensate (makes sure power steering pump has enough
power to drive it while doing low rpm operations such as parking - could be
bad pressure switch or short or open in wiring between switch and ECM
Check fuses and make sure some control circuit fuse has not blown - this
often causes multiple trouble codes.
tbaxleyjr
i tested the tps and thats work and also i tested the egr with a vacuum
tester....but when i went to check the fuses i noticed that one was missing
so i looked a little harder and noticed that they took and broke off the
holder for the fuse and that fuse goes the check engine and most of the
dash lights o yeah its a 92 lx my power steering pump leaks like crazy but
would that cause that pressure switch to be faulty
kcheifs28
