car forums
help, Saturn trunck issue
For full features; Go to help, Saturn trunck issue
i got a 2002 Saturn SC2, the vechical thinks the trunks open... so now my keyless doesnt work nor does my power door locks, or interiour lights...
anyone run into this issue or know what i need to do posted by  mrjj
Other than learning how to spell,..... you could check the sensor. Check the fuses. posted by  thefonz
no need to be a dick, it was an honest mistake..
but I have check the connections and they all seem fine, ill check the fuses, see if there somethings listed for trunk posted by  mrjj
Not being a dick. For such a short paragraph, plus the title, and three mispelled words..... Well I had my doubts. Good luck with your fix. BTW, all the fuses could be checked with a cheap tester in just a minute or two, and no need to pull them. posted by  thefonz
I'd check the catch inside the trunk and make sure it's catching. You said the vehicle thinks the trunk is open...do you mean the trunk light is lit on the console? posted by  97Talonchik
