car forums
1995 Chevy Corsica Dome Light
For full features; Go to 1995 Chevy Corsica Dome Light
I have a 1995 Chevy Corsica and the dome light doesn't work. I have checked the fuses and they are all look good and the light bulb looks good too. I can't figure out why it is not working. Does anyone know what the problem could be? posted by  lilhotch14
what ur gonna have to do is get down and dirty and trace some wires. posted by  DARKtEAGLE
when you say they look good, do they just look good or did you test them, as in put a meter across them and test for continuity? some times looks can be deceiving, especially with electronics. posted by  dvdrose18
I tested the fuse, prongs for the light, and bulb with a volt meter and they all tested positive. posted by  lilhotch14
I am assuming the dome light is supposed to come on when the door is open.
does the door chime if you leave the keys in the ignition or the headlights on?
is there an override switch that turns the light off?
is there voltage at the fuse
Basically you have to start somewhere and see if you have power. If not, go upstream, if yes go downstream. A wiring diagram is extremely helpful. posted by  dvdrose18
