For full features; Go to 92 Honda Accord EX acceleration problem...
Hi, My car has no power when going uphill only (2000 rpm tops even when
pedal to metal!) then what I do next is released the gas pedal and step on
it again and the car runs normal. This is what I have done to the car after
I have bought it 3 wks ago:
- Tune up (Sprk Plgs, Dist/Rtr, PCV & hose, Air filter & Oil & Filter)
- Replace Timing Belt
- Water pump & Coolant
- Thermostat
- Alt Belt
- Main Belt
- Valve cover gasket
- Tranny oil (Flush/Refill)
- Throttle Body Clean
The car also idles weird when in "P" (idles goes up and down 1500-1000
rpm)
and shakes a little bit when in "R" gear. Any suggestions!?!
thanks,
JD
jdalupan39
this information won't help me, but it might help others.
does it matter what speed you are going when you go up a hill, like is it
ok if you are going 30 MPH up a hill but not when you are going 55 MPH?
dvdrose18
i think its a torque converter problem.
DARKtEAGLE
