car forums
Radiator help
For full features; Go to Radiator help
I have a 95' Saturn SL1 about a week ago I blew a coolant hose. When i removed the bad hose the coolant that poured out was rather rust colored and appeared to have a fair amount of rust in it. I replaced the hose and for good measure i was going to flush the radiator with water to get rid of some of the rust. I filled the coolant tank, idled the car, and refilled it when the water pump kicked in. Everything was fine till i tried to drain it. When I opened the radiator drain valve nothing came out.
My question is why isn't it draining? is the drain clogged with rust? could the radiator be clogged somewhere else in the system? and what should I do?
Im not the best mechanic so please help, and try to keep the technical lingo understandable. posted by  thebannanaman
Does your radiator have a cap? There could be a type of pressure lock in the system if you only have one opening, like a straw when you close the top with your finger and the liquid doesn't come out. Opening the resevoir may work too, maybe better as it may drain the whole system.
If this doesn't work, I would consider taking the radiator out to drain it from whre the radiator hoses go in and getting a better look at whats going on.
I'm by no means an expert, hopefully somebody more knowledgable will chime in, just saying what I would do. Also, I believe that coolant has an anticorrosive chemical in it, if so it there shouldn't be rust in it. posted by  giant016
I recently bought a radiator flush kit. It needs to be spliced into a line, usually the one going to the heater core. The peice has a cap that you can plug your garden hose into. Also it comes with a director peice for the radiator cap(so the fluid being flushed out doesn't get all over the car). It was only like $3 but made the job a lot neater than just sticking a hose into the radiator and cost a lot less than having it professionally done.
If you do go this route I reccomend getting an anti-freeze tester. With all the water your pushing through, when refilling you wont know if you get the proper mixture. Also be sure the heat is turned on so the heater core opens and I believe they say to remove the thermostat and replace the housing while flushing.
I don't know about your drain, maybe like he said you've got a vapor lock. However if the fluid is nasty, like you said, flushing it would be a good idea. posted by  DBain
i believe most radiator caps are like one way valves, so they let air in, but not out, so it should drain, if only slowly, even with the cap on. however, if the colant is rusty, the cap may be clogged as well.
Keep in mind that if the coolant is that dirty, the radiator may be clogged and need to be replaced, which may have contributed to the hose bursting due to too much heat and pressure. of course a hose from 95 is about due to be replaced anyway.
if your car has a cap on the top of the radiator, I would check to be sure the coolant is flowing well when the water pump is running and the thermostat is open, but be careful, coolant will get very hot, most thermostats open around 170 degrees
I, as well, am not an expert, just sharing my :2cents: posted by  dvdrose18
