car forums
The active ingredient in chocolate can cure cough
For full features; Go to The active ingredient in chocolate can cure cough
An ingredient in chocolate could be used to stop persistent coughs and lead to more effective medicines, researchers say. The study found that theobromine, found in cocoa, was nearly a third more effective in stopping persistent coughs than codeine (http://www.lookchem.com/cas-294/29485-83-4.html), currently considered the best cough medicine.
The researchers, from Imperial College London (ICL), said the discovery could lead to more effective cough treatments. Ten healthy volunteers were either given theobromine, codeine or a dummy pill during the trial, which also involved Royal Brompton Hospital and St Bartholomew's Hospital.
The researchers, writing in the online FASEB Journal, said that theobromine worked by suppressing vagus nerve activity, which is responsible for causing coughing. They also found that unlike standard cough treatments, theobromine caused no adverse effects on the cardiovascular or central nervous systems, such as drowsiness. posted by  chelsea8611
1) Unless I'm missing something, your link is relatively dead making you a spammer. However I'll go on...
2) The effect of theobromine on the vagus nerve and possibility to act as a cough supressant is absolutely nothing new. However, what you mentioned regarding its side effects is NOT true. It is a vasodilator (similar to asthma medications), dilates the blood vessels, and increases the heartbeat. This sounds like an effect on the cardiovascular system, don't ya think? Why would chocolate cause drowsiness? However, it has been known to cause sleeplessness, restlessness, tremors, and various other effects.
EDIT: I was too tired when I wrote that. It is a vasodilator (hence dilates the blood vessels...why did I mention it twice) but not similar to asthma medications (which are bronchidilators). It only works as an asthma medication by relaxing smooth muscles. posted by  Nissan_Altima
