For full features; Go to Wanting To Know Answer
Could someone tell me if parts off a 2000
xj8 Jaguar will fit a 2002 Vanden Plas Jag
Looking forward to this info
Thanks
thejagbunny
not sure, but it would be helpful to know what parts you are interested in
swapping.
corbett_auto
The Vanden Plas, due to it being a higher trim level, had a number of
variations in the trim (different grille and rear trim, differnt interior,
etc). it was also only available in the long wheelbase form, so if the XJ8
that you're looking at is the short wheelbase car (most were) then a number
of body and mechanical parts are different. The engines and transmissions
are identical between the XJ8 and the standard Vanden Plas (though in 2002,
the top Vanden Plas used a supercharged V8, but those cars are labeled as
Super V8s).
Depending on what you wnat to swap, most parts should fit, though often
there are legal issues with swapping an older engine to a newer car.
I wasn't aware that the Vanden Plas name was brought back....
