For full features; Go to my t-bird
i just got a 67 t-bird and when i put it in drive it goes but it reves out
to high and then finally it will kick down what should i do, and i need to
know where i can find a rear bottom bumper, and i cant get the signal
lights to work or break lights what can i try or what should i do
dunkley
first thing, check your trans fluid
second, check aftermarket. there has to be one out there somewhere
third, get a wiring diagram and follow your wires checking for broken wires
and good conections
glagon1979
i went on the net and got the wiring manual for it and i followed all the
wires and they seemed to be all right and i changed the bulbs in the lights
but i put the signal on and it goes on but it wont flash and if i take the
wire off the motor the motor for the lights will go but the lgihts wont
turn on and when i put the wire back on then the lights will go on and the
motor wont flash i had the steering colum apart and everything i cant
figure it out
dunkley
i dopnt know what to tell you then. i would need the car here to know what
exactly you are talking about
glagon1979
yea i know its hard to explain. the lights run off there own little motor
thing and its ****ed im not sure what to do im taking it to a shop tonight
when i get home hopefully they will know whats wrong with it and it wont
cost me to much it might be the whole wiring harness but hopefully not
because thats gonna cost quite a bit but i uno
dunkley
