car forums
455 oldsmobile crank
For full features; Go to 455 oldsmobile crank
has anyone had luck finding a reproduction forged steel crank, because I have look high and low and here is what I have come up with. I know that oldsmobile made about 4,000 of them, so your odds of pulling one of those out of a block are slim. Mondello sells these cranks for $1500. That seems pretty god D*** steep considering you can get an a new eagle one for a chevy 454 for half that. Eagle rods is coming out with a oldsmobile cast steel crank in spring, but I'm not sure if that will be strong enough for my build. Does anyone know the HP rating on a cast steel crank? Also does anyone know where I can get my hands on a forged steel one. posted by  fordslayer87
A standard cast 455 crank is good for 500ish hp and 600ish lb/ft of torque if properly prepped, ie proper machining practices, as long as you follow two important guidelines.
1. Install oil restrictors to keep more oil on the bottom end and less up on the top.
2. Keep the RPM fairly low. With a 4 1/4" stoke, you can twist the crank if you spin it too hard and it puts tremendous stress on the pistons due to high piston speed. Keep it below 5500, or maybe even 5000 and it'll last forever. posted by  vwhobo
I've already got the oil restrictors in the block, so I'm good there and I've also got a fully machined crank with a N stamp on it. Nodular iron I assume, but plans changed and now I'm shooting for 700hp so stock bottom end components are going to hold up. posted by  fordslayer87
I've already got the oil restrictors in the block, so I'm good there and I've also got a fully machined crank with a N stamp on it. Nodular iron I assume, but plans changed and now I'm shooting for 700hp so stock bottom end components are NOT going to hold up.
opps forgot the not in first reply posted by  fordslayer87
Slogan T-shirts from $15
itself Slogan T-shirts
SELL YOUR CAR
@ CF Classifieds
