For full features; Go to 1965 Mustang convertible
I just purchased a 1965 Mustang convertible, 289, 4 speed man. trans. It is
very badly rusted out underneath. :ohcrap: It is sagging and the doors are
hitting. Anyone got any advice on where to start replacing metal, how to
brace, and how to square it up? It hasn't moved for at least 10 years (I'm
renting the garage it is parked in) and has 4 flat tires that don't hold
any air. any good ideas how to get it off the ground without twisting it
out of shape? I will try to add pictures once i get up to the garage with a
camera, maybe Friday. Any ideas would be appreciated.
dvdrose18
If it is so badly rusted that it is sagging in the center, I recommend that
you find a less rusted car to use to build the project. Mustang are
relatively inexpensive...and you can use the 289 and 4 speed in the new
body...
If this option doesn't work for you and you want to rebuild this one, be
ready for a great deal of work. The best way to get it back into shape is
to completely strip it down to the bare shell. Remove every part that is
bolted to the car. Now that you have most of the weigh removed, you can use
jack stands to support it. Use at least 8...position one under each torque
box 2 under the radiator support and 2 at the rear of the rear frame rails.
If it is as bad as I suspect, you will need to install a new floor (they
sell a 1 pc), inner & out rockers, all four torque boxes, rear frame rails,
upper and lower cowl, 1/4 panels, inner & outer wheel wells, trunk drop
downs and all the front fender aprons. The car will not really line up
until you get all the metal back on and it is solid again. It is very
important that you properly align all of the metal before you weld it in to
place. You will need to get a factory assembly manual to get the factory
measurements.
My sig has a picture of a 66 convertible we just finished a few months
back.
Hope this helps...if you need more specifics just ask.
corbett_auto
I'd do what Corbette_Auto said, and use the Mustang you have now as a parts
car for a car that's not literally falling in due to rust.
67Coronet383
Unfortinately(sp?) it is hard to find one around here in northern NJ that
wouldn't be just about as much work that is reasonably priced, and I don't
have the room for another car.
The floors look like chicken wire, but the hump over the transmission
looks ok, so I hope to use just 2 full pans. Other than that, I am realy
just interested in making it drivable for now, then decide if i want to
keep it and do a full restoration, or sell it. But i will probably end up
doing everything once i get started. But it will probably take me 5+ years
on a student budget and schedule, just spending weekends and vacations
working on it.
And another question. Would one of those portable garage things on a level
driveway be an ok place to work on it? or do i need a better idea?
Or am I completly insane for even considering restoring this car?
dvdrose18
It sounds as though you purchased a car with some good options...but if the
car is as bad as you describe.....you may be better off with one that needs
less work. Restoration can become very frustrating when you bite off more
than you can chew and based on your questions you have more than a
mouthful.
You do not need to necessarily get rid of it. Maybe find an easier project
to get your feet wet. Get one that just needs a tune-up and a brake job.
Drive it around for a while, sell it for a profit, then buy one that needs
a little more work....then repeat. After a few years will have gained the
skills, money, tools, place to work and patience needed to dive into a
project like the Mustang.
corbett_auto
I guess I've passed the point of no return, I realy want to fix the car up.
As for skills and tools, my brother is working on a 67 mustang coupe, so he
has a some tools, and some experience, so with his help and my dad's, I
think I can make it through some of the more difficult times. And I figured
if I realy run out of patience, I could sell it as a parts car and probably
break even.
Thanks for the advice, even if I am too thick headed to listen
dvdrose18
Is there any way you could post some pictures of it? I'm curious as to how
bad the rust damage is. I have experience restoring and building cars, it's
what I do. I can tell you a lot more from a picture.
67Coronet383
I will try to get pictures friday or saturday, but i have to see when i
have time, a camera, and access to the garage.
dvdrose18
a month and a half late, i finally got pictures, and brought the car home.
I know these pictures can't tell you much about the over all shape of the
car, except in the second to last image where you can see the ground
through the floor behind the drivers seat. clickify for larger
http://i178.photobucket.com/albums/w269/dvdrose18/th_001lightened.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/001lightened.jpg)_http:/
/i178.photobucket.com/albums/w269/dvdrose18/th_007lightened.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/007lightened.jpg)_http:/
/i178.photobucket.com/albums/w269/dvdrose18/th_65mustang002.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/65mustang002.jpg)
http://i178.photobucket.com/albums/w269/dvdrose18/th_65mustang004.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/65mustang004.jpg)_http:/
/i178.photobucket.com/albums/w269/dvdrose18/th_65mustang005.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/65mustang005.jpg)_http:/
/i178.photobucket.com/albums/w269/dvdrose18/th_65mustang017.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/65mustang017.jpg)
http://i178.photobucket.com/albums/w269/dvdrose18/th_65mustang021.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/65mustang021.jpg)_http:/
/i178.photobucket.com/albums/w269/dvdrose18/th_65mustang037.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/65mustang037.jpg)
dvdrose18
The hole in the last picture is in the inner rocker panel. This is a very
hard panel for a novice to repair. Floors and fenders are not so bad, but I
recommend you proceed with caution. The inner and outer rocker are what
holds the car together.
The rest of the car looks really good, but the structural damage looks bad.
You really should consider finding a donor vehicle with a better body.
The next step you should take is to remove the seat and carpet. Then vacuum
out all of the dust, dirt and rust flakes...then look it over really
good...this will give you a good idea of where you stand.
corbett_auto
SAGGING...?
I think the frame rails might be toast.
My suggestion is to take the drivetrain out and drop it in a better suited,
less trashed body.
Get a same year 200ci inline 6 cylinder car. They can be had for cheap. Or
better yet, just find a shell.
Well I did two things since I last posted. First of all I drove it around
the block a few times, I just love the way it drives. It took a bit of
work though, because when I opened the gas cap, I realized it still had
what appeared to be about 10 gallons of gas still in it, after its been
sitting for 10 years. After I siphoned out as much as I could, I found
about an inch of a thick, tar like substance in the bottom of the tank. Not
fun. So for the moment, I have my brothers gas tank and sending unit in it,
so I could drive it around. The other thing I did was pull out the seats
and carpet. See pictures below, click for larger.
http://i178.photobucket.com/albums/w269/dvdrose18/th_carpetup010.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/carpetup010.jpg)_http://
i178.photobucket.com/albums/w269/dvdrose18/th_carpetup009.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/carpetup009.jpg)_http://
i178.photobucket.com/albums/w269/dvdrose18/th_carpetup008.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/carpetup008.jpg)
http://i178.photobucket.com/albums/w269/dvdrose18/th_carpetup007.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/carpetup007.jpg)_http://
i178.photobucket.com/albums/w269/dvdrose18/th_carpetup006.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/carpetup006.jpg)_http://
i178.photobucket.com/albums/w269/dvdrose18/th_carpetup005.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/carpetup005.jpg)
http://i178.photobucket.com/albums/w269/dvdrose18/th_gastank008.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/gastank008.jpg)_http://i
178.photobucket.com/albums/w269/dvdrose18/th_gastank007.jpg
(http://i178.photobucket.com/albums/w269/dvdrose18/gastank007.jpg)
edit: I forgot to mention that I hope to go to Carlisle PA Saturday to pick
up front torque boxes, 2 complete rockers, 2 full floors, 2 frame rail
floor supports, and 2 convertible reinforcement pans. Anything else I
should get while I am there?
dvdrose18
MUCH better shape than my brothers was
I say do it, but only if you can realize just how big of a project it will
be
as for tips... it would help to be a welder/fabricator lol
Make sure that you are getting the inner rockers. You may also need the
outer, but I can not tell from the pictures. And be ready for a lot of
work. Replacing the inner rockers is a very difficult task.
Once you get the parts lay them all out and develope a good game plan. You
will also need to buy or borrow a few tools to do a good job. And the main
thing to remember is take your time. There are a lot of parts you will need
to take off and save such as the seat platform. We normally just buy a new
one because it is cheaper and faster than trying to save the old one.
As you dig deeper into it don't be affraid to come back and ask questions.
You will get your share of smart a$$ answers, but a few of us will try to
help if we can.
corbett_auto
I'm getting the complete rocker, its got the inner, the outer, and the
front extension all stitched together. And what tools would you be
referring to? I (my father) already have a couple air tools, spot welder,
Mig welder, grinder, etc. And also, when you replace the rockers, is it
wise to weld braces across the door openings, or is it better to leave the
doors in to line things up, and put braces somewhere else?
dvdrose18
You can get by with just a cut off wheel and drill. But an air chisel and a
good spot weld cutter make things go a little smoother.
AS I mentioned what you will need to do once you have the new pieces is pay
close attention to how the factory put the car together...then what you
want to do is reverse the process, replace the needed parts and then
re-assemble. Along the way yuou may discover that a few other pieces may
not be reuseable..if so you will need to repair them or replace them...
As far as braces go it doesn't really matter. If I was doing it, I'd leave
the doors off and take a lot of good measurments from multiple points on
both sides and square everything up the best you can and brace it
accordingly.... If you install the braces out of the way of the doors, then
you can mount them after you tack it all together to be sure everything
lines up....What you are after is a straight line between the door and the
1/4 and along the rocker panel. Take your time ligning up the doors. It is
not an easy thing and could take you all day to get one side done, but all
of the time spent will be worth it in the end...
The other thing you need to do is figure out how the water got in the car
and caused the problems....A common problem in Mustangs is the cowl...Here
is a picture of what they normally look like. This picture is after the
upper section was removed:
http://www.corbettsauto.com/pictures/misc/DSCF1252.JPG
If you dont stop the water leaks it will eventually rust out again.
corbett_auto
I think the cowl is fine, or not too bad, because I didn't see any leaves
in it, and when I poured a gallon of water in each side, none came in the
car, so I think the water may have come from a poorly sealing or torn top,
as the original owner had the top replaced. I know my brothers looked like
that, but I think mine might be ok.
I already have the air chisel, and a bunch of cheep Harbor Freight spot
weld cutters.
dvdrose18
well the car has set for almost a year and as it gets warmer I can't wait
to start working on it. Here is my plan of action.
1. Since I am working in a tent in the back yard, I want to build something
like a floor to work off of(unless my brother moves out and takes his car,
then I get the garage :drool: ) I am figuring run 2 4x4's for 16 feet,
approximately under the tires. on top of this I would run 2x4's or 2x6's on
end crosswise to build a floor. Then there would be 2x6's or 2x8's parallel
to the 4x4's for the tires to run on, and later for a jig to rest on.
2. I plan on building a jig similar to this. one set of supports to the
bumper brackets, one set just behind the front shock towers under the frame
rail, and one set to where each of the rear spring shackles attach to the
rear frame.
http://krpandr.com/media/mustangjig.JPG
3. remove engine, transmission, doors, fenders, convertible top,
suspension, etc.
4. get car onto jig, and put braces across the doors
5. replace rocker panels and torque boxes
6. replace front frame rail extensions under the floors
7. replace the floors
8. repair rear frame rail
9. repair engine bay
10. repair rear wheel wells
11. reinstall suspension and drive train
12. repair/replace fenders, doors, etc.
13. final cosmetics and assembly.
14. take it for a spin
15. wrap it around a tree
16. wake up in ER
Estimated cost: $18,000 to $20,000 plus hospital bills
ETA: Fall 2015
any opinions?
dvdrose18
That seems reasonable... Just be sure you hold everything plumb, square,
perpendicular, parallel, etc...... otherwise final fit of the panels will
be way off.
When you write it all out it makes it sound easy... which it is if you take
it step by step and take your time. Your budget and time frame also sound
like you have thought it out.
We have done lots of Mustangs and have a lot of pictures of replacing
various items if it would help.... Due to the link posting restrictions I
will not post a link, but feel free to email or PM if you want to see
any.... We actually just finished the rust repair on a 68 Convertible that
needed many of the things yours needs.
corbett_auto
Well, a little update as to what is happening...
Shortly after posting the last update, I got another job, so now I am
working per diem as a nurse, maintain 8 lawns in the neighborhood, work
part time at a local mom and pop shop, and go to school full time, so as
you can imagine, life is busy, so the car has, for the most part, been
sitting untouched. Before the semester started, I removed the front:
bumper, bumper supports, valance, parking lights, headlights, and grille
and valance.
Since my brother finally moved his car and most of his parts to his house,
I will be moving into the garage soon (before it snows!), so hopefully over
Christmas break I can get some real work done.
dvdrose18
i wish you the best of luck and really you dont have it to bad ya its
a mountain of work but i have seen cars from the 90's with more rust
than metal just like a few of us have said take it slow and in
... depending on how much time ya got you will look back and well feel
good haha but other than that floor bits and such just make sure to
save as much as you can never know how hard it can be to find a
part...
well best of luck
i look forward to seeing the progress :drool:
btw when ya wrap it around a tree can i have it?
chillmiller
A little update:
Got her in the garage in early December, so I have been able to get some
work done. Conv. top is off, fenders and hood are off, radiator is out,
exhaust has been removed, working on taking the glass out.
Got a cart for the engine to go on, so once I can make arrangements to
borrow an engine hoist, and I get a free weekend, the engine and trans will
be pulled out.
There has been a slight change in plans: So far it looks like I won't be
building a jig, but rather I'm leaning toward using an assortment of jacks
and stands to hold things in shape while I work on the rockers and frame.
And it looks like most of the suspenssion will be staying in for ease of
menuverability. As you can see, there isn't much room in the garage, so I
will need to be able to roll it out to the driveway.
Picture from shortly after I got it in the garage:
http://i178.photobucket.com/albums/w269/dvdrose18/Mustang/Picture009sml.jpg
dvdrose18
sounds like things are moving in the right direction. And jack stand will
work great to hold things in place while you work. On convertible we
typically use 8: 2 at the very front under the frame rails, 2 near the
torque boxes under the front frame rail, 2 at the rear torque box near
where the leaf springs mount, and the last two at the rear under the frame
rails.... It will be just fine as long as you take your time jacking it up.
Only go a little at the time, do not jack the front all the way up and then
jack the back all the way up. Do it in about 3-4 stages. If that makes
sense.
Good luck and remember to take your time. In the end you will be glad you
did.
corbett_auto
Engine, trans, and drive shaft came out Tuesday without any problems at
all. :heh: In fact it went MUCH smoother than I had feared. Noted a few
more things that will need to be replaced. The front springs have all but
worn through the upper control arms, and the clutch is shot.
Time to assemble a shopping list so I can finally get started on some of
the body work.
dvdrose18
If the front spring are bad you make want to take a little time and decide
if you want to upgrade the front suspension. If not at least replace all of
the bushing. The easiest way to do this is to buy complete new upper and
lower control arm which come with new ball joints and bushing installed.
corbett_auto
well the plans have changed again.:doh:
After thinking things through again, it appears as though I will be
building a body cart after all. Dad doesn't want me welding in the garage
if I can avoid it, due to the fire hazard. Aside from that, there isn't so
much room to maneuver large parts around (as you can see in the above
picture). Also the driveway isn't in good condition and a little short on
space (4 cars, 5 when my brother is home) so I don't want to leave the car
in the driveway while I work on it. Also decided it wasn't a good idea to
leave the car on its own wheels, because it would be to easy for things to
shift out of proper alignment, especially when moving over the uneven
driveway.
That being said, all of the suspension is out. Quite a fight to get the
rear springs out, ended up taking a sawzall to the front bolts to get it
free. the steering came out all to easy, basically fell out, more parts to
add to the shopping list...:ohcrap:
Now the problem is building a cart to spec, so it will hold the car squarer
than it is now, and not get in the way when I replace the inner and center
rocker panels, front torque boxes, floors, floor reinforcement pan, etc.
Well, most of the disassembling is finished, time to start fixing some
things...:drool:
Decided this post needed a picture: My brothers new ride, it's in our
blood:
http://i178.photobucket.com/albums/w269/dvdrose18/P7140011.jpg
dvdrose18
What you describe pretty much sums up most restoration projects: Full of
challenges and new directions. If you keep the motivation up it helps
things move more smoothly. Good luck! :thumbs:
corbett_auto
